How to limit users based on bytes in and bytes out combined?
Hello!
I read the manual and searched the forum, but to no avail.
I have a hotspot setup that works well. Now I would like to limit certain hotspot users based on their traffic. I know that you can limit users using limit-bytes-in OR limit-bytes-out, but there’s no hotspot parameter for both in and out combined. How if I want limit a user to 100MB for upload AND download? Any work around anyone?
Thanks!
Anyone?
There have been 23 views so I’m sure any recommendations, tips or even just ideas or hints on this subject will be appreciated by many forumites.
Thanks!
If you are familiar with radius, you can set up (almost) anything you want :slight_smile:
You can monitor the users traffic every 5 mins (for example) and then run a script that will simply delete his interface after he run out of bytes available.
Hope this helps
