How to log all critical info onto the HD
Hi there
Im busy running version 2.9.5, is there any way to log all critical activaty to my HD or to email it too me..
Ive had ppl try to hack into my system and i need to log all the info.
Also How do you turn of logging for ospf.i could do it in version 2.8.7
If anyone could give me a step by step guide.
Kind Regards
Shane
use remote logging with some syslog daemon
any recomended syslog daemon tools
not a specific one, but you can get some here:
http://freshmeat.net/search/?q=syslog&section=projects&Go.x=0&Go.y=0
thanks.will try…is there a step by step guide how to set this all up
