How to log into the access points in a wireless network on a mikrotik server pc?
Need your help please.
Impossible to answer without details. What kind of access points? What’s the network layout? What are you trying, and how is it failing?
access points tplink
ips for accesses (network) : 192.168.0.0/24
ips for lan network layout 10.0.0.0/24
wan network layout : 192.168.1.0/24
I am trying to log into the access points while the server is on but I can’t.
الحمد لله لقد وجدت الاجابة الصحيحة
1- Give a static ip to the access point(withen the range of your lan network). Don’t let the server give it an ip then make ip bending with its ip , mac address and choose bypass.
2- Make ip bending as well to the computer through which you want to log into the access point and choose bypass.
