How to log some information
Dear all,
Can anyone help to give simple example on how to log to a file (on other machine) of some of mikrotik’s information such as the wireless signal strength, noise, etc ?
This simple example will help a lot. Later i will try to modify it to get more important data.
Is it also possible to show (for example signal strength of wlan1 interface) on mrtg (is there any link to the tutorial) ?
Regards,
Teddy
This may be helpful:
http://wiki.mikrotik.com/wiki/Manual:SNMP
