Hi
i have instaled ntp package and i need to logging ntp server. can anyone help. standar logging does not work for this package.
thanks
Hi
thanks
note from the documentation:
NOTE: the above logging rules work only with the built-in SNTP client, the separate NTP package doesn’t have any logging facilities.
In regards to the sntp client take a look at the wiki:
Background on how to configure logging http://wiki.mikrotik.com/wiki/Manual:System/Log#Logging_configuration
Log messages explained → http://wiki.mikrotik.com/wiki/Time#Log_messages
Hi
Yes, i saw this in documentation. So I nedd another option how to do it.
If you want to use the logging functions available on the S-NTP client, uninstall the NTP package.
Go to system → packages, select the NTP, hit uninstall and reboot.
The use do not “want to use the logging functions available on the S-NTP client”, want use NTP server and there is no way to logging it’s operation.
