At the moment I have 50 clients coneected to a miktotik router 2.9.27.
they are connected via wireless, there are times when everything goes ok, but there are times when there is a lot of time outs and high ms.
I think I diden’t know how to put the firewalls and the filters in the right way. So can any one please tell me how to do that.
How to make a perfect firewall with perfect filters , please post me all the needed codes if possible.
hi normis, i’m having the same problem, you said to upgrade and check p2p. i have got v2.9.35 and yes, the people are using p2p, how can i setup up the correct p2p queues?
I have tried to stop p2p but it is imposible to resolve the problem, I still have lots of time outs between clients in my network. the quality of the service is really bad to my clients. I do not know what to do. I have many many different rules in my firewall and still have problems.
so in my router I have one interface as AP wlan1 and two others as Local, Public.
Can any one help me resolve this. It would be very helpful if you could paste all the needed codes and everything like ports that should be blocked needed so my network can work perfectly like it used to before I formated it
Yes I have 50 clients in 1 AP in Wireless Prism, and I have about 10 cleints connected in Localy.
I have 3 MBits of bandwidth,
Hardware used: Intel pentium III - 600 Mhz, 30 GB HDD, 256MB of Ram.
I understand you guys, but this network used to work pretty good with even less bandwidth, when I formated my router and had to re setup it everything has changed, that’s becasue I think I haven’t put all the filters and firewalls in the same way.
If somebody could help me by posting the needed codes or by chating online on a dedicated time whenever you think is the best time. This is my personal e-mail address: rsn_@msn.com
