How to make a virtual Access Point from Laptop with Mikrotik RouterOS ???
How to make a virtual Access Point (vAP) from Laptop with Mikrotik ??
  • I did download and build a Mikrotik RouterOS on VMware Workstation 12 by a vmdk file on homepage Mikrotik.
  • My Laptop have wireless Driver :
  • Dell Wireless 1705 802.11b/g/n (2.4GHz).
  • Realtek PCIe FE Family Controller .
    My question:
  • I want to add wireless interface for Mikrotik but i can’t. Is that why i can’t creat vAP on RouterOS ???
  • how to add wireless interface for Mikrotik RouterOS from VMware Workstation ??
Thanks so much.
I am afraid that wlan is not supported in virtualized environment by ros. Using whatever Ap mikrotik device is much more economical in my opinion.
Wireless adapters are not supported in virtualized environments period. RouterOS or no RouterOS.
Or to put this another way… You should take up this as a feature request to VMware.
(Other hypervisors like VirtualBox and Qemu don’t support this either… But if one hypervisor supports it, I’m sure the rest will follow soon…)
VMware ESXi supports PCI passthrough allowing a VM to directly access a physical PCI device connected to the hypervisor.
I haven’t tried using any wireless device on ESXi before, so I don’t if it actually works with ROS.
Here’s the relevant KB article by VMware https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1010789
