how to make cash server between ipdslam and wan router
hi
i want to make server in order to control my bandwidth
my network is consists of wan router and dslam to distrbuite my ba ndwidth between the user
wan router ip : 82.129.227.129
ipdslam : 82.129.227.130
plz any body can explain what about ip wan card and ip lan card
and thanks
what’s your problem? have you read the manual?
you should read the refernece manual and look for web proxy/ transparent proxy, it will tell you how to set it up, just put the ip on your mt and lose the other box, or route to it or put it in the bridge, just make sure you have the traffic running thru the mt some how , you could also port forward to squid or another cache server, mt also has a caching dns you can use
