Hey guys!
I need to disable routing on the Cloud Router Switch crs125-24g-1s-rm ?
I will appreciate your prompt reply!
Thanks,
Katia
Hey guys!
Thanks,
Katia
Just set all ports as slave ports to a single master port in the interface menu and there is your switch.
111
a problem came up - the boot process stuck on “starting services” and I get the following errors:
00:00:08 system,info router rebooted
00:01:55 system,error,critical login failure for user usb 1-1: device not accepting address 5, error -71 via local
00:06:03 system,info,account user admin logged in via local
00:09:55 script,error system,error,critical login failure for user usb 1-1: device
00:10:26 script,error system
What should I do next?
