How to make it so users CANT change passwords in UM
Does anyone know how to make it so under the http://UM-router-ip/user users are not able to change there passwords?
I am using MT established pppoe sessions so if they change the password on the UM the MT client will not authenticate.
thanks
you can create a firewall rule in the input chain that drops port 80 TCP packets from the customer network
Then the user could not view their statistics, right?
I would like to see the same thing. If a user checks how much usage they have that is ok, but you don’t want them changing there user name and password while they are in there.
Was there any answer to this. The answer above looks like it would stop the user altogether.
Was there an answer for this. It should have a tickbox to remove the option from the user side where they log in.
i also asked for this but didnt get it i aske for them to add in two passwords one just to login to stats with two passwords sections
i for interface and one for connection password
