is there any way to set it as SNTP server?
so when another device connect to him he will get the time from it?
Thanks ,
I don’t see any option for it?
do i need to install something ? is there a SMTP package ?
I’m using V6.32.2
Thanks ,
Thanks ,
I’m using V6.32.2
Thanks ,
Yes it’s possible, you only have to download NTP package:
More info can be found here:
http://wiki.mikrotik.com/wiki/Setup_local_NTP_servers
Extra packages can be downloaded here:
http://www.mikrotik.com/download
I feel dumb right now…
I was looking for SNTP package and not NTP ![]()
thanks ,
