How to make PS5 work on mikro tik router?
i live with my brother and we have AT&T Fiber. he recently replaced the perfectly fine AT&T 620 router with a mikro tik “cloud core” 2004 modem, U circles and some metal stick where the wire goes into.
my PS5 says nat type failed. how do I get it back working? how do I log into the router? I can’t use 192.168.1.1.
I rebooted the router so many times I don’t know where the 620 router is otherwise I’d plug it back in and set the mikro tik and u circles on fire.
Primo:
Could you please reformulate the problem to more readable form without slang?
Not all users are English based teens.
Secundo:
Please try to recall yourself where you have put the AT&T modem. There is no dependency between count of CCR reboots and the place where the modem "rests in peace".
We have no idea how your brother configured the MikroTik. Ask him. Maybe it is intentional he blocked your PS5?
And why would you try to log into someone else's equipment without asking the owner ?
The 2 most obvious solutions to this are
  1. Engage with your bother to fix the config issue
  2. Ask your brother to restore the AT&T router
This is not necessarily the best forum for working on brotherly relations, so in that spirit, perhaps your next option is to get your own router - if you have the ISP logon credentials. Do you have anything which works on the new setup?
If you are using a wired connection, you could try some of the other ports on the router.
