Hello!
Help please!
How to make telnet connection from mikrotik to other system or device?
Thanks.
Hello!
Help please!
Thanks.
/system telnet
Through a script it does not work.
Sure it won’t work. If you want to use telnet for command execution on other boards use linux box and “expect” script.
What do you have in view of under “linux box”? PC under handle linux?
I have a task to leave from PC and linux OS.
There is any other solution to control a microtik from other microtik?
Thanks.
