Dear sir,
How to make the web proxy transparency in RouterOS 4.6 by using winbox? as it is easy in RouterOS 3.x simple enable checkBox but in RouterOS 4.6 there is no such check box to enable it..
Dear sir,
there is no checkbox, but you have to make one DST_NAT rule. very simple:
http://wiki.mikrotik.com/wiki/How_to_make_transparent_web_proxy
Thanks,
I have a question, find out when the proxy nat, nat rules I have in some users to give public ip stops working. I can do to solve this problem?
