I have a MK with a /22 subnet announced.
Bellow that MK, i have several servers, each one on his own vlan.
Each vlan have a /30 configured has follows (This is a example, my IPs are all public):
10.0.0.0: Subnet
10.0.0.1: Router IP
10.0.0.2: Server IP
10.0.0.3: Broadcast IP.
Everything works perfectly. I can ping the servers and the servers can ping between them and the internet.
Now, my problem is when i add IPs failover or Subnet Failover to the server…
1st problem: To add a /32 IP, i do this on the router:
/ip route add comment="Failover IP for Server 1" distance=1 dst-address=10.0.1.1/32 gateway=SRV01 pref-src=10.0.0.1
After i configure the IP on the server, i can ping that IP from internet. But… I can’t ping it from other vlans. why?
2nd problem: To add a /28, i do this on the router:
/ip route add comment="Failover Subnet for Server 1" distance=1 dst-address=10.0.1.0/28 gateway=SRV01 pref-src=10.0.0.1
On the server i configure all ips has /32.
The problem is that i can’t ping the IP’s 10.0.1.0 or 10.0.1.15 from internet or other vlans. why? How can i make all the IPs accessible?
I got it working. The problem was in my firewall rules.
For your info:
This configuration works perfectly well because SRV01 is the interface. MK already configure SRV01 has gateway when i add the ip address to that interface.
I would still suggest to change from interface to IP address. Even if it works at the moment, it may cause problems in the future. Interface gateway on broadcast network can trigger unexpected behavior.
Ok.
I’ve tested like you said, to put the IP address instead of the interface… It doesn’t work.
I loose full connection if i put the ip instead of the interface.
Also… what IP should i put?
If i put the interface IP, MK tells me that the subnet is unreachable.
If i put the server IP, MK tells me that the subnet is reachable, but i can’t ping or have connection on those IPs.
The only way to get it working is to put the interface for gateway.
