how to make visible local network behind hotspot ...
I have problem with a visibility of a local network behind a hotspot.
Installed hotspot works well on a pool network 10.10.1.0/24 but behind a hotspot (ether2) there are 2 Linux servers configured on the 192.168.210.0/24 subnet (192.168.210.10,20).
Gateway IP - 192.168.210.1/24 is assigned on ether2 and I tried to configure IP-bindings in order to make visible Linux servers from an outside without success.
ether1 is an uplink port.
Does anybody have experience how to solve such a problem … maybe to use firewall/mangle rules ?
Tested Mktk.: v3.0beta5
appreciate every help or suggestion.
Thanks,
D.
add static route 192.168.210.0/24 to one of your hotspot as Linux Router Gateway.
Hope it’ll work.
Thank you for the answer but I think I didn’t properly understand …
where to put a static route ?
My hotspot router has ether1 (uplink) and ether2 (hotspot) …
Thanks again,
D.
In case addresses are available at the public space, then you may use this configuration example,
http://wiki.mikrotik.com/wiki/How_to_link_Public_addresses_to_Local_ones
IP → Route → Add
192.168.210.0/24 set the gateway to one of your hotspot host (eg: 10.10.1.1)
Is it clear ?
:laughing:
  • Rio.Martin -
    Ym: riomartinz
Just to let you know that I have solved the problem !
IP bindings works well !
The only thing is that ‘Address’ and ‘To Address’ sections have to have the same IP.
I have also entered the MAC field.
Thanks all of you guys for your suggestions and help.
D.
you just need to enter mac field and select ‘bypass’ on the bottom.
