Thanks Samsoft for your suggestion! i will use it for my last resort.
anyway, here corrected and tested configuration:
ip firewall mangle print
136 ;;; icmp-packet-upload
chain=prerouting action=mark-packet new-packet-mark=icmp-packet-upload passthrough=no protocol=icmp in-interface=vlan5-noc
137 ;;; icmp-packet-download
chain=prerouting action=mark-packet new-packet-mark=icmp-packet-download passthrough=no protocol=icmp
138 ;;; test-conn
chain=prerouting action=mark-connection new-connection-mark=test-conn passthrough=yes src-address=172.16.31.89
139 ;;; test-packet-upload
chain=prerouting action=mark-packet new-packet-mark=test-packet-upload passthrough=no in-interface=vlan5-noc connection-mark=test-conn
140 ;;; test-packet-download
chain=prerouting action=mark-packet new-packet-mark=test-packet-download passthrough=no connection-mark=test-conn
queue tree print
120 name=“test-parent-upload” parent=global-in packet-mark=“” limit-at=128000 queue=default priority=8 max-limit=100000 burst-limit=0 burst-threshold=0 burst-time=0s
121 name=“test-parent-download” parent=global-in packet-mark=“” limit-at=128000 queue=default priority=8 max-limit=1000000 burst-limit=0 burst-threshold=0 burst-time=0s
122 name=“icmp-priority-download” parent=test-parent-download packet-mark=icmp-packet-download limit-at=128000 queue=default priority=2 max-limit=128000 burst-limit=0 burst-threshold=0 burst-time=0s
118 name=“icmp-priority-upload” parent=test-parent-upload packet-mark=icmp-packet-upload limit-at=128000 queue=default priority=2 max-limit=128000 burst-limit=0 burst-threshold=0 burst-time=0s
119 name=“test-user-download” parent=test-parent-download packet-mark=test-packet-download limit-at=128000 queue=defaul priority=8 max-limit=128000 burst-limit=0 burst-threshold=0 burst-time=0s
0 name=“test-user-upload” parent=test-parent-upload packet-mark=test-packet-upload limit-at=128000 queue=default priority=8 max-limit=256000 burst-limit=0 burst-threshold=0 burst-time=0s
queue type print
13 name=“pcq-128k-up” kind=pcq pcq-rate=256000 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=5000
14 name=“pcq-128k-down” kind=pcq pcq-rate=128000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=5000
My testing procedures are:
- try to use full bandwidth
result: all are good. ICMP can get good result.
- try to disable(#122,#188) priority and shapping of ICMP packet, and use full bandwidth
result: user can get the top speed (D:128k,U:256k) BUT ICMP still good. i think mangle excluded ICMP from user connection already as Samsoft said
if ICMP is your problem so : isolate it , exclude it by mangle , give it a simple unlimited queue , put this q always on top of other simple q’s , it wont take much bandwidth at all ..
- try to change from ICMP to HTTP protocol. just to make sure that user cannot use over the bandwidth as Janisk said
This way we get virtually the same behaviour as “per user prioritization”
Here is new configuration:
136 ;;; http-packet-upload
chain=prerouting action=mark-packet new-packet-mark=icmp-packet-upload passthrough=no protocol=tcp in-interface=vlan5-noc dst-port=80
137 ;;; http-packet-download
chain=prerouting action=mark-packet new-packet-mark=icmp-packet-download passthrough=no protocol=tcp dst-port=80
queue tree print
118 name=“http-priority-upload” parent=test-parent-upload packet-mark=icmp-packet-upload limit-at=128000 queue=default priority=2 max-limit=1000000 burst-limit=0 burst-threshold=0 burst-time=0s
122 name=“http-priority-download” parent=test-parent-download packet-mark=icmp-packet-download limit-at=128000 queue=default priority=2 max-limit=1000000 burst-limit=0 burst-threshold=0 burst-time=0s
result: user can use over bandwidth. that mean, PCQ can not help.
