I would need to mark download and upload packages that go from my VLANs to pppoe in order to track and prioritize traffic.
My router is an RB1100AHx2.
eth1 set as management
eth2 is my WLAN pppoe port (ADSL), connected to the modem.
eth3 and eth4 are in bonding and it’s a trunk (VLAN10 - VLAN20 - VLAN30) connected to Switch1 (CRS125, 24 ports, rack mounted).
eth9 is a trunk (VLAN10 - VLAN40 - VLAN 60) that connects to a switch (CRS125, 24 ports, wifi) via a ubiquity antenna to a remote location (Site n.2)
eth10 is a trunk (VLAN10 - VLAN50 - VLAN 60) that connects to a switch (CRS125, 24 ports, wifi) via a ubiquity antenna to a remote location (Site n.3)
eth11 is a trunk (VLAN10 - VLAN30 - VLAN 70) that leads to a wifi access point.
Taking the VLAN10, for example, how should I set up the mangle rules to mark packets in uploads, ie those that start from devices belonging to the VLAN10 and exit from pppoe?
VLAN10 —> pppoe
And those who do the reverse route, ie from pppoe, come to devices belonging to the VLAN10?
VLAN10 <— pppoe
I tried this, without success:
Chain = prerouting
Dst.address = 10.10.10.0/24 (VLAN10 subnet)
In.interface = my pppoe
Action = mark packet
New packet mark = Office-IN
Chain = postrouting
Src.address = 10.10.10.0/24 (VLAN10 subnet)
Out.interface = my pppoe
New packet mark = Office-OUT
The first rule gives no signs of life, packets 0
The second doesn’t work.
I do not understand the logic. I tried to look for tutorials, readed the microtik manual, tryied out some forum configurations, watched videos on youtube … but I cannot figure it out.
You talked about “sources” and “destinations” but in simple queues I can see only “target” and “dst.”, I tryed to find some examples online but I cannot understand how It works… can You help me give me an example?
Thank You very much!
It’s my understanding that simple queues require fasttrack to be off (disable the default rule in the firewall). I’d then mark the packets with mangles by source or destination similar to what you did. I’d then use the packet-marks to match it into the queue you want.
/queue simple add target=my-ppoe packet-marks=LimitTheScrubs1 limit-at=56000/56000 comment="Limit everything sourced from 10.10.10.0/24 that needs to leave via my-ppoe to dial-up speeds."
With this method you can only limit how fast your sending data via that interface. You also can’t control what comes down my-ppoe from the provider. The provider may still be filling the pipe between you and them with traffic that you are then only junking or trying to slow-down.
I have fasttrack dummy rules on… I triyed to disable them but I cannot.
I tryied to switch my forward rules from “fasttrack connection” to “accept”…but still I cannot disable fasttrack dummy rules.
Is there no method that allow to control also the traffic from pppoe to my subnets?
You can only control how data is processed from your ppoe connection. You can’t control what enters your ppoe connection from your ISP. In other words you can’t control at your router what comes down the ppoe connection your ISP would need to queue that traffic for you for it to be most effective.
Think of it terms of a water pipe. The queue mechanism is the valve that controls how much flows past it. The only valve you can control is your router. I can fill the pipe in front of your valve, the ISP connection, completely up. In order to prefer some traffic into the pipe between you and the ISP the valve at the ISP would have to be adjusted.
It’s that reason I tend to not worry to much about ingress queueing on the Internet, PPPoE, side.
I’d imagine we’d want them in postrouting. The mangle rules take affect before NAT but if we are matching the mangle rule based on out-interface it wouldn’t know that until after the routing decision is made.
To clarify one thing. Ingress or input queuing isn’t always a negative idea. I use it at the access layer commonly to verify, correct or apply QoS markings to traffic. Shaping on ingress or input is just largely useless especially on the Internet pipe. This would be moving more into the topic of QoS on a large campus network. Likely not what you’re working on. The last bit I’ll leave you with is that QoS is meant to better manage tail drop packet loss. What this means is it helps your router to identify which traffic should be dropped and or preferred when queuing traffic out of an interface. Typically in a campus LAN you’re not going to have a problem with congestion as most of our Internet connections are significantly smaller than the links within our campus. The exception being any link like a point-to-point wireless connection or something. The moral of the story is that QoS isn’t the end all be all. It’s a tool, when used correctly it can greatly improve the quality of important traffic but it is not a replacement for bandwidth when that’s what’s really needed.
Really thanks! It’s all clear! I have the mangles in “postrouting”… I don’t know why I wrote “prerouting”…
Thank You very much for the explanation!
PS: The last question: about the queues types, have You got some advices? I read that “default-small” can cause a bigger amount of packet loss and someone suggest to use “default” is this right?
PPS: Is there a way for me to add You reputation points? I triyed but I think I cannot..
No problem, I learn a lot by challenging myself to help others solve their problems. I find I learn the best when I force myself to try and explain a technology to others.
The queue size is really up to you and your environment. I wish I could find the video from way back in the early 2000s when I was in school…
Basically the queue depth is what you are configuring. If your rule backs up a lot of traffic in the queue you are telling it how many packets to hold onto before dropping them. Think of a queue managing say SMB from a server. You download a 100MB file and the queue is setup to limit speeds to dialup to and from the server (56kbps). Packets will start backing up in the queue. How many packets do you want to hold onto before you start dropping them? Default-small means 10 packets, default means 50. Each packet takes up resources to hold onto and inevitably some will be dropped which result in re-transmission from the client anyways. In some cases you don’t care if packets fall on the floor in others you do. For example a voice queue while maybe limited in bandwidth you want to place significant queue depth to ensure you have a buffer in place in case of congestion before you can update the queue size.
So if you are following it’s really just another knob for us to turn as we build out rule-sets. I haven’t tried to monitor the queues in RouterOS yet but I imagine and hope you can track queue depth related drops like you can in Cisco land so you know if you need to adjust your rules or just to know at least how much traffic your queues are dropping.
As far as rating you can rate me personally by viewing my profile I believe. I’ve struggled trying to upvote posts in the past. I EMAILed support and apparently there is supposed to be a smiley face icon by each post but I don’t see that so I’m not sure you do either.
