How to match "$" in a string?
How to match “$” in a string?
I couldnt input “\$” in layer7 regexpression in terminal, How to deal with it?
I want to make a script, I am blocked on my way for it .
Thanks.
Maybe “\$” (if you want to receive “$” inside the regexp)? First backslash means to leave the second backslash without its “special” meaning. So you need third backslash, that will work on $ :wink:. But then you will be looking for “$”. If you want to look for just $ - I think “$” is enough :slight_smile:.
thanks a lot
