How to merge VPN and existing network in one subnet?
Hi.
I’m trying to setup VPN on remote site, so I can access IP cameras. I have deployed Hap as VPN server. My issue is whit subnets. Those IP cameras are not accessible from different subnet, so I have to be on same subnet. VPN configuration is default, I set it up in Quick Set menu. By default VPN creates 192.168.89.0/24 pool as distributes IP from it, but I have to be on 192.168.253.0/24 subnet as IP cameras are configured on it. No, I can’t reconfigure cameras as I need to reset them, as I don’t access credentials. So in my desired configuration VPN should add client device to existing 192.168.253.0/24 subnet so I can access cameras remotely. I have changed local ip in PPP>Profiles to 192.168.253.120, but still no luck. hap can ping 192.168.253.120 as expected, but other client devises “cannot see” VPN client.
My ROS configuration: https://pastebin.pl/view/8b50db83 . It is from my VM test lab, but principals hold.
PS: VPN client I use is Win10 build in.
If you use the same subnet for VPN and for your local bridge you need to set arp to proxy-arp on the bridge.
Thank you for answer, but still I’m unable to access cameras. I can access any other device on network, except cameras.
PS: Those are Hikvison DS-2CD2032-I cameras, i can access them on remote site.
The same network segment takes layer 2 VPN, and different network segments can be routed.
