How to mesh tow xr2 in RB433?
Hello.
i have installed tow xr2 mini-pci in RB433.(AP)
what is the configuration to mesh be running ?
can i broadcasting in one SSID ?
How much customer bears each one card ?
can i use one antenna or i must to use tow ?
Thank you
Ok thank you for no answers :slight_smile:
i have anther question but i think it’s easy to answer me plz
what’s the maximum power In(Vote and Amber ) can i plug it to board Model (RB433)
When it have tow mini-pci cards working in mode (Ap bridge)
each one card have 50 client online ?
can i use the sane channel in both ?
thank you . :slight_smile:
about the voltage and the ampers you can look in routerboard.com product pdf file.
Yes, you can connect 50 clients to each AP, but know that you will not get high throughput if all your clients will transmit at the same time.
You can use the same frequency if the antenna points different direction, but if it points the same direction I recommend to use different one so they do not interfere with each other.
For each wireless card you should have one antenna.
okay thank you :slight_smile:
