Friends
Is there any way to migrate all my settings from my old RB493 to my new RB493G, probe with backup and restore and stays dead, I have to reset and return to zero
Regards
Osvaldo Paez
Rosario-Argentina
Friends
Regards
Osvaldo Paez
Rosario-Argentina
open Terminal screen
export file=backup
then check your files
download file dragging to your computer.
Connect your new router
login via winbox
list your files
drag your backup to root directory
open terminal screen
write:
import backup.rsc
done…
The RB493 and RB493G have different ethernet switch chip architectures so take care when doing this.
If you are slaving ethernet ports to a master port (using a layer 2 switch block), the rules change.
The RB493 has a single switch block for ports 2-9.
The RB493G has a switch block for ports 1 and 6-9 and another switch block for ports 2-5.
You can bridge the two blocks together if needed.
All else should work the same.
Tom
Thanks, is what he had tried but did not work
Regards
Osvaldo
