hi,
Got the original enclosure for RBM33G and the rear holes for the pigtail antenna connectors are too big. Obviously I’m missing a part or a plate that has properly sized holes. Is there some sort of mounting adapter and how’s the name?
The enclosure comes with 4 plastic thingies that fit perfectly well in the holes but they are definitely not designed for the antenna connector to be screwed on them.
But the question is, what should you do, when you want to use small RSMA connectors? I’ve seen people drilling new holes. Pair of thin metal washers, as non-destructive method, did the trick for me. But I also wondered if there was some kind of official adapter or something.
I don’t want to ruin the otherwise nice enclosure. I’d drilled holes in the top already otherwise. It’s the best option to give some space to the 4 antennas I need to mount
