Hi. I have 750gl already installed . We have to replace it with rb3011us. There are 2 wans. With failover. As rb3011us has two socs. Two switches. I want to use it as all ports acting as a same entity. Same as in 750. How can i do that.
Thanks.
Thanks.
If you were not using the switch, just set master ports of all ethernets to none. Or describe your desired result in more detail.
OK , will that make both switches work together as a single unit (switch) by software means as in 750GL ? Sorry for such nub question. !
You can bridge the master ports of the switches in case there are more switches in the device.
