how to NAT on a DHCP defined interface
I would like to build a standard configuration of MT Router as generic hotspot system for deployment to multiple locations.
I wish to make the lan interface DHCP assigned so that i can just ship the device to the destination, then they just plug it into their network and it goes…
but in order to make the wireless segment work, I need to NAT the wireless network to the lan interface address - which i do not know until it is assigned.
How would i add this rule so that it will work with whatever ip address is assigned on the lan interface?
Thanks and regards, Mike Everest.
you can do that using masquarading:
/ip firewall src-nat add action=masquerade out-interface=<outinterface>
Magnificent!
I thought I had tried that before, but couldn’t get it to work. Now I do it again, and this time no problemo! :slight_smile:
Thanks plenty,
regards, Mike.
