Is Eth1-gateway the only WAN connection?
Is eth3 connected to the internet?
If Eth1-gateway is the only connection, and those are public ips on eth3 with no internet connection, then you will need to get the ISP to route those public ips (111.222.115.105/29) to 111.222.114.26 for you.
If that isn’t it, explain how you are connected to the internet.
On my first post I put what I’ve got from ISP. And according to ISP they did route on their end and now I have to do it on mine.
eth1 is plugged in to their media converter (internet through fibre)
eth2 i’m using for now to have internet in the office
eth3 should be my 111.222.115.104/29 network
I would check with your ISP to see what they have done. There is a difference between putting that subnet on your WAN interface, and routing the subnet to the ip assigned to your WAN interface.
Now ISP is telling me that they did P2P IP forwarding of /29 through /30. In worst case scenario I will have to ask them to remove /30 and use one of the IP from /29 as a gateway. This way I’m going to be down to only 4 public IPs unless I can do something else with RB configuration
Best,
