Hi dude…
how can i netinstall on this unit???
Hi dude…
This is a wireless card. What you mean by Netinstall on it ??
http://routerboard.com/R5SHPn
ops…
i mean metal R5SHpn…
You mean Metal 5SHPn
It is the same as any other device, connect to a PC with Netinstall, push the button, plug in the PoE power adapter, and follow instructions http://i.mt.lv/routerboard/files/Metal-5SHPN-qg-fcc.pdf
when i power up, i can see there is one solid L.E.D then beep sound…
after that, it’s not respond at all…
i try with the guide, it won’t go to netinstall as how the RB433 work for me…
should i ask for RMA in this situation???
try to push the button right AFTER you plug in the power, this should work too. also, try to simply count to 20 seconds, then release. Maybe LED has problem, not the device.
