Hello guys,
I am a total noob in RouterOS (but gut a mikrotik router because of its performacne and stability).
I need to open port 44158 for my Helium Sensecam miner.
This is what I have done so far but it seems like I got something wrong since it is not working properly and port seems still closed.
My setup is simple - Mikrotik router - Internet acces in Ethernet1 - Helium miner connected to Ethernet 10 ( I have public IP)
In firewall - NAT - I have set up
Chain : dstnatn
Dst. address : “my public ip address”
Protocol : 6 tcp
Dst. port : 44158
In. interface : all ethernet
Action : dst-nat
To address : 192.168.0.97 (which is the helium miner address)
To ports : 44158
In Firewall filter rules- I have set up
Chain : forward
Dst. address : 192.168.0.97 (which is the helium miner address)
Protocol : 6 tcp
Dst. port : 44158
Action : accept
(I have also moved it to position 2 right after the accept input rule)
Are my settings correct or should I change something? (could my ISP be blocking the 44158 port?)
Thank you very much for any help
