How to output print to a PC file?
I tried >> to output print results to a file but it didn’t work. What is the trick? And where will the file be (what directory)?
For example,
system package print >> versions.txt
did not work.
Backup Mikrotik config to Subversion/SVN repository via SSH
sshpass -p $sshpassword ssh $sshuser@$sshhost -p $sshport export >$current_export_name
This make an export in to local file on your Linux PC.
You have to use the export command, for example:
/ip firewall filter export file=filter
this will create a file with rsc extension in the files of routerboard.
You can copy paste that file and open with with notepad.
system package print file=versions.txt
This make an export in to file on ROS.
