How to Pass all traffic into WireGuard Cloudflare ?
Hello Guys,
I have questions, how do I pass all traffic into WireGuard Cloudflare VPN?
I follow this tutorial https://www.youtube.com/watch?v=2pFcVRaoscE, but when I add mangle or routing rule, my winbox disconnects from the router and cannot connect via IP.
In that tutorial, the wireguard traffic is only for a specific range of IP addresses, and some websites like this forum cannot be accessed.
I try to ask chat GPT, to help me, but none the answer work. https://chatgpt.com/share/671ac348-32ac-8001-80a2-a30cbbb24294
Winbox cannot connect through an IP address.
Winbox can connect through an IP address.
Tplink Switch Vlan configuration.
the rsc config
# 2024-10-25 05:18:02 by RouterOS 7.16.1
# software id = #
# model = RB941-2nD
# serial number = #
add admin-mac=# auto-mac=no comment=defconf \
    ingress-filtering=no name=bridge port-cost-mode=short vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=indonesia distance=indoors frequency=auto installation=indoor \
    mode=ap-bridge ssid=Scale wireless-protocol=802.11
/interface wireguard
add comment="Cloudflare WireGuard" listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add comment=guestconf interface=bridge name=vlan22 vlan-id=22
/interface bonding
add name=bonding1 slaves=ether3,ether4
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys supplicant-identity=MikroTik
add eap-methods="" name=guest supplicant-identity=""
/interface wireless
add keepalive-frames=disabled mac-address=# master-interface=\
    wlan1 multicast-buffering=disabled name=wlan2 security-profile=guest \
    ssid="Scale Guest" wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
    0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
    0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
add name=guest-dhcp ranges=192.168.84.2-192.168.84.8
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=guest-dhcp interface=vlan22 lease-time=10m name=guestconf
/queue simple
add max-limit=1M/1M name=queue-guest target=vlan22
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add comment="Cloudflare WireGuard" disabled=no fib name=to-Cloudflare
add bridge=bridge comment=defconf disabled=yes ingress-filtering=no \
    interface=ether2 internal-path-cost=10 path-cost=10
    interface=ether3 internal-path-cost=10 path-cost=10
    interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=pwr-line1 \
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 \
add bridge=bridge ingress-filtering=no interface=bonding1 internal-path-cost=\
    10 path-cost=10
add bridge=bridge ingress-filtering=no interface=wlan2 internal-path-cost=10 \
    path-cost=10 pvid=22
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,bonding1 untagged=wlan2 vlan-ids=22
add interface=ether2 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment="Cloudflare WireGuard" \
    endpoint-address=engage.cloudflareclient.com endpoint-port=2408 \
    interface=wireguard1 name="cloudflare wireguard" persistent-keepalive=35s \
    public-key="#"
    192.168.88.0
add address=192.168.84.1/28 comment=guestconf interface=vlan22 network=\
    192.168.84.0
add address=192.168.100.100/24 comment=wan1 interface=ether1 network=\
    192.168.100.0
add address=192.168.2.100/24 comment=wan2 interface=ether2 network=\
    192.168.2.0
add address=172.16.0.2 comment="Cloudflare WireGuard" interface=wireguard1 \
    network=172.16.0.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add comment=defconf disabled=yes interface=ether2
/ip dhcp-server lease
add address=192.168.88.2 client-id=# mac-address=\
    # server=defconf
add address=192.168.88.6 mac-address=# server=defconf
add address=192.168.88.3 client-id=# mac-address=\
    # server=defconf
add address=192.168.88.4 client-id=# mac-address=\
    # server=defconf
add address=192.168.88.5 mac-address=# server=defconf
add address=192.168.84.0/28 comment=guestconf gateway=192.168.84.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=192.168.100.1 name=wan1.logi.lo type=A
add address=192.168.2.1 name=wan2.logi.lo type=A
add address=192.168.88.6 name=stb1.logi.lo type=A
add address=127.0.0.1 name=stb2.logi.lo type=A
add address=192.168.88.4 name=eap1.logi.lo type=A
add address=192.168.100.254 name=cpe1.logi.lo type=A
add address=192.168.88.2 name=switch1.logi.lo type=A
add address=192.168.88.3 name=switch2.logi.lo type=A
add address=192.168.88.5 name=tlmr1.logi.lo type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=drop chain=forward comment="guestconf: drop to ether2" \
    in-interface=vlan22 out-interface=ether2
/ip firewall mangle
add action=change-mss chain=forward comment="Cloudflare WireGuard" new-mss=\
    1380 out-interface=wireguard1 passthrough=no protocol=tcp tcp-flags=syn \
    tcp-mss=1381-65535
add action=masquerade chain=srcnat comment="Cloudflare WireGuard" \
/ip ipsec profile
/ip kid-control device
add mac-address=# name="Redmi-10C;2" user=""
add mac-address=# name="ESP-67B077;6" user=""
add check-gateway=ping comment=Recursive disabled=no distance=1 dst-address=\
    0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=10 \
    suppress-hw-offload=no target-scope=12
add check-gateway=ping comment=Main disabled=no distance=1 dst-address=\
    8.8.8.8/32 gateway=192.168.100.1 routing-table=main scope=10 \
    suppress-hw-offload=no target-scope=11
add check-gateway=ping comment=Backup disabled=no distance=2 dst-address=\
    0.0.0.0/0 gateway=192.168.2.1 routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add comment="Cloudflare WireGuard" disabled=no distance=1 dst-address=\
    0.0.0.0/0 gateway=wireguard1 routing-table=to-Cloudflare scope=30 \
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/routing rule
add action=lookup-only-in-table comment="Cloudflare WireGuard" disabled=no \
    min-prefix=0 table=main
add action=lookup-only-in-table disabled=no src-address=192.168.88.0/24 \
    table=to-Cloudflare
add action=lookup-only-in-table disabled=no src-address=192.168.84.0/28 \
    table=to-Cloudflare
/system clock
set time-zone-name=Asia/Jakarta
/system note
set show-at-login=no
/system scheduler
add interval=2d name=reboot on-event="/system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2021-02-28 start-time=16:32:56
add interval=2h name="dns clear" on-event="/ip dns cache flush" policy=\
    start-date=2021-02-28 start-time=16:35:12
add comment="trigger duckdns updater" interval=1m name="duckdns updater" \
    on-event="/system script run duckdns" policy=read,write,policy,test \
    start-time=startup
/system script
add comment="duckdns updater" dont-require-permissions=no name=duckdns owner=\
    admin policy=read,write,policy,test source=":local resolvedIP [:resolve \"\
    #.duckdns.org\"];\
    \n:local currentIP [/ip cloud get public-address];\
    \n:local currentIP [:pick \$currentIP 0 [:find \$currentIP \"/\"]];\
    \n\
    \n:if (\$resolvedIP != \$currentIP) do={\
    \n    :log info (\"Trying to update DuckDNS with actual IP \".\$currentIP.\
    \", resolved IP is \".\$resolvedIP);\
    \n    :local response [/tool fetch url=(\"https://www.duckdns.org/update\?\
    domains=#&token=\
    \#&ip=\".\$currentIP) check-certificat\
    e=yes as-value output=user];\
    \n    :if (\$response->\"status\" = \"finished\") do={\
    \n        :if (\$response->\"data\" = \"OK\") do={\
    \n            :log info (\"Successfully updated DuckDNS with new IP \".\$c\
    urrentIP);\
    \n        } else={\
    \n            :log error (\"Failed to update DuckDNS with new IP \".\$curr\
    entIP);\
    \n        }\
    \n    }\
    \n}"
/tool mac-server
/tool mac-server mac-winbox
any suggestions?
I’m still learning about network forgive me if I do lot of mistakes, thanks :slight_smile:
My network configuration is figured in the attachments.
# model = RB941-2nD
serial number =
/interface wireless
add comment=“Cloudflare WireGuard” listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge name=home-vlan10 vlan-id=10
/interface bonding
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=“”
add eap-methods=“” name=guest supplicant-identity=“”
/interface wireless
ssid=“Scale Guest” wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/ip kid-control
add address-pool=default-dhcp interface=home-vlan10 lease-time=10m name=defconf
/queue simple
/routing ospf area
/routing table
add comment=“Cloudflare WireGuard” disabled=no fib name=to-Cloudflare
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=wlan1 pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=wlan2 pvid=22
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=bonding1 pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=ether4 pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=pwr-line1 pvid=10
set udp-timeout=10s
/ip settings
/ipv6 settings
add bridge=bridge tagged=bridge untagged=bonding1,wlan1,ether4 vlan-ids=10
add bridge=bridge tagged=bridge untagged=wlan2 vlan-ids=22
add comment=defconf interface=home-vlan10 list=LAN
add interface=vlan22 list=LAN
set auth=sha1,md5
add allowed-address=0.0.0.0/0 comment=“Cloudflare WireGuard”
interface=wireguard1 name=“cloudflare wireguard” persistent-keepalive=35s
public-key=“#”
add address=192.168.88.1/24 comment=defconf interface=home-vlan10 network=
192.168.88.0
192.168.84.0
192.168.100.0
192.168.2.0
add address=172.16.0.2**/24** comment=“Cloudflare WireGuard” interface=wireguard1
network=172.16.0.0
/ip dhcp-client
server=defconf
server=defconf
server=defconf
/ip dns static { FOR WHAT PURPOSE all the below static settings??? }
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=drop chain=forward comment=“guestconf: drop to ether2”
/ip firewall mangle
add action=change-mss chain=forward comment=“Cloudflare WireGuard” new-mss=
tcp-mss=1381-65535
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat comment=“Cloudflare WireGuard”
/ip ipsec profile
add mac-address=# name=“Redmi-10C;2” user=“”
add mac-address=# name=“ESP-67B077;6” user=“”
add comment=“Cloudflare WireGuard” disabled=no distance=1 dst-address=
/routing bfd configuration { FOR WHAT purpose is this rule ???}
/routing rule
add action=lookup-only-in-table comment=“Cloudflare WireGuard” disabled=no
table=to-Cloudflare
table=to-Cloudflare
{WHAT IS the purpose of this rule??? Where did this subnet come from??
/system clock
/system note
/system scheduler
add interval=2d name=reboot on-event=“/system reboot” policy=
add interval=2h name=“dns clear” on-event=“/ip dns cache flush” policy=
add comment=“trigger duckdns updater” interval=1m name=“duckdns updater”
on-event=“/system script run duckdns” policy=read,write,policy,test
start-time=startup
/system script
add comment=“duckdns updater” dont-require-permissions=no name=duckdns owner=
admin policy=read,write,policy,test source=“:local resolvedIP [:resolve "
#.duckdns.org"];
\n:local currentIP [:pick $currentIP 0 [:find $currentIP "/"]];
\n
\n:if ($resolvedIP != $currentIP) do={
\n :log info ("Trying to update DuckDNS with actual IP ".$currentIP.
", resolved IP is ".$resolvedIP);
\n :local response [/tool fetch url=("https://www.duckdns.org/update\?\
domains=#&token=
#&ip=".$currentIP) check-certificat
\n :if ($response->"status" = "finished") do={
\n :if ($response->"data" = "OK") do={
\n :log info ("Successfully updated DuckDNS with new IP ".$c
urrentIP);
\n } else={
\n :log error ("Failed to update DuckDNS with new IP ".$curr
entIP);
\n }
\n }
\n}”
/tool mac-server
I’m following your configuration, but i got ERR:Could not connect, MacConnection syn timeout. Why ?
And why i should make new home vlan and add it on bridge ?
Now i cant get access to my router board, with Mac address on all port or ip :slight_smile:
The config was not intended for you to blindly copy and get into trouble, it was there to generate questions and discussions.
Until you understand what I touched upon and answered the ambiguities and questions, there is no point in changing any of the config.
In terms of making changes to the config on any MT device I highly recommend using a port NOT on the bridge ( might have to take one off the bridge temporarily).
Give it an IP address, and make it part of the LAN or Trusted interface list and do all the config from that port, especially if monkeying with bridge and vlans.
set [ find default-name=ether5 ] name=OffBridge5
add address=192.168.68.1/30 interface=OffBridge5 network=192.168.68.0
/Interface list members
add interface=OffBridge5 list=TRUSTED
Simply change ipv4 settings on laptop to match 192.168.68.2 and you should be able to config the router.
My router RB941-2ND only has 4 ports.
    • ether 1 > wan 1
  • ether 2 > wan 2
  • ether 3, 4 > bonding to a TP-Link switch.
because you say when I’m trying to try config, I need one port dedicated to ‘offBridge’ / debugging purposes. Then I chose port 4, and because of it, I should unbound ports 3 and 4.
here is the new configuration
2024-10-28 02:57:36 by RouterOS 7.16.1
software id =
model = RB941-2nD
serial number =
/interface wireless
set [ find default-name=ether4 ] comment=debugging
/interface vlan
add comment=guestconf interface=bridge name=guest-vlan22 vlan-id=22
add comment=default-home-conf interface=bridge name=home-vlan10 vlan-id=10
/interface bonding
add disabled=yes name=bonding1 slaves=ether3,ether4
/interface wireless
/ip kid-control
defconf
add address-pool=guest-dhcp interface=guest-vlan22 lease-time=10m name=
guestconf
/queue simple
add max-limit=1M/1M name=queue-guest target=guest-vlan22
/routing ospf area
/routing table
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10
path-cost=10
→ this port connect into a switch, pvid 1, frame types admit all, ‘because when i put pvid 10 and frame types admit-only-untagged-and-priority-tagged its not working, the switch and access point can’t read the vlan. in this port i let through vlan 10 home and 22 guest’
add bridge=bridge comment=defconf interface=pwr-line1 internal-path-cost=10
path-cost=10
→ i don’t know which port that use in here ?
add bridge=bridge comment=defconf frame-types=
admit-only-untagged-and-priority-tagged interface=wlan1
internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes ingress-filtering=no interface=bonding1
internal-path-cost=10 path-cost=10 → temporary disable, since port 4 as debugging purpose
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged
interface=wlan2 internal-path-cost=10 path-cost=10 pvid=22
set udp-timeout=10s
/ip settings
/ipv6 settings
add bridge=bridge tagged=bridge,ether3 untagged=wlan2 vlan-ids=22
add bridge=bridge tagged=bridge,ether3 untagged=wlan1 vlan-ids=10
→ if i put ether 3 untagged the vlan not working, then i put it in tagged as far i know its called trunk port, do im wrong here ?
add comment=debugging interface=ether4 list=LAN
add comment=mynet interface=home-vlan10 list=LAN
add interface=guest-vlan22 list=LAN
set auth=sha1,md5
public-key=“#”
192.168.88.0
add address=192.168.84.1/28 comment=guestconf interface=guest-vlan22 network=
192.168.84.0
192.168.100.0
192.168.2.0
add address=172.16.0.2/24 comment=“Cloudflare WireGuard” interface=wireguard1
network=172.16.0.0
add address=192.168.68.1/30 comment=debugging interface=ether4 network=
192.168.68.0
/ip dhcp-client
server=defconf
server=defconf
server=defconf
/ip dns static → is this affect the network ? as far as i know im set this because i want that devices can be access by URL name not only IP address. is this the wrong way ?
invalid
in-interface=guest-vlan22 out-interface=ether2
→ i don’t want guest to access the backup network, so i dropped it.
/ip firewall mangle
tcp-mss=1381-65535
/ip ipsec profile
0.0.0.0/0 gateway=1.1.1.1 routing-table=main scope=10
1.1.1.1/32 gateway=192.168.100.1 routing-table=main scope=10
#error exporting “/ip/upnp” (timeout)
add disabled=yes interfaces=all min-rx=200ms min-tx=200ms multiplier=5 → i don’t know the purpose of this config, since my config is edited from default/factory configuration when the mikrotik first-time boot/after factory reset.
/routing rule
table=to-Cloudflare
table=to-Cloudflare
→ i add this because i think it make guest network will flow through the VPN too.
/system clock
/system note
#error exporting “/system/ntp/client” (timeout)
/system scheduler
start-time=startup
/system script
#.duckdns.org"];
\n
domains=#.duckdns.org&token=
urrentIP);
\n } else={
entIP);
\n }
\n }
\n}”
/tool mac-server
after all of that, Still cannot access the router via IP address. same as before. why ? any suggestions ?
On accessing the router by IP address… do you mean using winbox, I always use macaddress for the very simple reason its easier and available and just need to click on it.
If I use IP address I have to actually physically type in the IP address and remember also the winbox port ( one of the first things I do is change the default winbox port ).
To confirm you want all traffic both vlan10 home users and vlan22 users to go out wireguard for internet.
If so, why are you concerned about vlan22 (guests using wan2) by the forward firewall rule (blocking it) . We will be sending all its traffic out wireguard not wan1 or wan2 ???
Does this imply that if the wireguard is NOT available for some issue at the other end ( not your local WAN ), they you want your home users to then access local internet?
These types of requirements details affect config design!!
Also confusing is why are you using two wans. If all lan traffic is going out WAN1 through the wireguard tunnel, why waste money on WAN2.
You are leaving out key information, especially on the purpose of the WANs.
As for the TP link switch is configured incorrectly but you left out some of the other TP link config screens to confirm either way???
The single or bonded ports on the router
/interface bridge ports
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether3
( or bonding1 ) is correct its a trunk port to the switch.
/interface bridge vlans
add bridge=bridge tagged=bridge,ether3 ( or bonded1) untagged=wlan1 vlan-ids=10
is correct
add bridge=bridge tagged=bridge,ether3 ( or bonded1) untagged=wlan2 vlan-ids=22
On the Switch I expect to see.
VLANID
1 ----> default: Tagged member on trunk ports ( aka port coming from router, and any port going to another smart device )
10 ----> home: Tagged member on trunk ports, untagged for any ports going to dumb home devices
22 -----> guest: Tagged member on trunk port coming from router, Untagged for any ports going to dumb guest devices.
Port PVID settings.
For any dumb port you sent the vlan ID of the vlan on that port (either 10 or 22 ).
For any dumb port not yet assigned, use vlan ID of 1 ( should already be set as default anyway )
Thus vlan1 is NOT a member of any ports going to dumb devices.
For any smart ports assigned, the pvid remains vlan ID1 the default.
SO, basically pvid=1, unless the port is an access port for a vlan ( aka going to a dumb device ).
What I cannot recall off the top of my head is whether the trunk ports are left tagged or untagged for vlan1…
you might want to play with that to confirm.
Mac address cannot be use in Mikrotik Home App, and that app is very simple UI to monitoring the router, thats why I need IP address to access the router., and why with this vpn implemented it’s not working?, I’m trying to experiment on Routing->Rules, on 192.168.88.0/24 subnet, I add marking to main table then route lookup to-Cloudflare tables, but this is not stable, sometimes I can access sometimes not, also the connection looks like ambiguous, why ?
In here I just want to share my main internet ‘ether1/wan1’ to my neighbors using guest access, but if the main internet down the neighbors will be restricted to access to backup internet/ether2/wan2 because in here backup is using quota limit/ the internet access is limited by the provider and expensive.
No, I just want all internet is through to vpn, home/guest will use vpn, because I think it’s more secure :slight_smile:
If something happens with that VPN, in client devices simply disconnect from this network, and directly connect into wan, because both of the wan spread wireless network.
This mikrotik network will be act like vpn firewall maybe ? :slight_smile:
I mean, If I want internet that using vpn, simply I connect my client devices into this network :slight_smile:
The Wan2 it’s connect to a mobile 4g devices, it’s only use if the main internet fiber optic Wan1 is down.
I have 8 iot devices that connect into this home network, if wan1 down I can’t controll those devices, so why I still need wan2 as backup, because it’s very hard if I should reconnect those iot devices into my mobile 4g network :slight_smile:
Any suggestions?
I’m sorry, the switch that I use only one, and I need adjustable for the new config. Here is the new config for the switch. Is that correct ?
On the switch port, the port 1 and 5 is directly to a client devices, and i want that client to get IP from home subnet, then i untagged port 1 and 5 for vlan 10 its should be correct right ? but why i get unidentifying network on my laptop ?
It’s should be pvid=1 right ?, I try change frame-types from admit-all to admit-only-vlan-tagged, then it’s not working, admit-only-vlan-tagged it’s mean only for vlan 1 ? but this port should through vlan 10 and 22, why admit-only-vlan-tagged ?
> is correct
VLANID
tagged means if any incoming / outcoming port for many vlan, while untagged mean single port for single vlan ? am I correct ?
Port PVID settings.
For any smart ports assigned, the > pvid > remains vlan ID1 the default.
should vlan 1 be tagged into all ports? default configuration on the switch and bridge vlan is untagged for vlan1, is this correct?
  • What’s the different between my first configuration ? My first configuration, the bridge directly connected on the subnet 192.168.88.0/24. But in new configuration that subnet is connected to home-vlan 10, what the difference of this configuration ?
Okay, I think I understand.
All LAN traffic will go through VPN.
VPN will use WAN1.
If WAN1 goes down, you want only HOME users to be able to access WAN2 during this time.
Please confirm that WAN2 traffic should also go out VPN for internet and not directly WAN2 to www.
On the TPLINK Switch
  1. VLANID1 is NOT a member of port 1 and 5.
    PVID of port1 and port5 should 10.
    VLAN10 should be an UNTAGGED member of port 1 and 5.
  2. VlanID1 is NOT a member of port 2
    PVID of port2 is 22
    VLAN22 should be an UNTAGGED member of port2
  3. VLAN10 Should be a tagged member of port3, port4 ( or bonded lag )
    VLAN22 should be a tagged member or port3, port4 ( or bonded lag )
    VLAN1 should be an untagged member of port3 and port4 ( or bonded lag )
Your bridge diagram doesnt seem quite correct yet…
However the config it came from would have been better to view.
/export file=anynameyouwish (minus router serial number, any public WANIP information, keys etc..)
The IOT devices should not be a problem. The VPN should move to WAN2 in case of failover…
This is correct until you add back in etherport 4, but lets get the rest of the config up and working first, all vlans, and wireguard working, then worry about bringing ether4 and lag/bond back up!!!
Now we need to see rest of config.
By the way use config quote marks at start and end of config to keep it short… the black square with white parenthesise on teh same line as Bold and Italics!!
Assuming cloudflare wireguard provided endpoint address endpoint port and private key and used the private key provided when creating the Mikrotik wireguard instance correct?
Also did they provide any DNS information to use??
Yes that’s right, VPN also use in WAN2.
    PVID of port2 is 22
on tp-link switch, port2 is used by tplink access point to spread the network, since the ap is support vlan, I should tagged on port2 right ?
is this new configuration correct ?, but why I still get unidentified network when I connect my laptop into port 1 or 5 ?
I figured it out, I should set pvid on the switch pvid menu settings, I just realized that pvid is stands for “Port VLAN ID” and is used to tag untagged traffic that enters a switch port. :slight_smile:
Now ports 1 and 5 on the switch can provide internet access to my laptop. :slight_smile:
But still, I can’t connect Winbox/Mikrotik home app through IP address into the router. why ???
Here is the new Mikrotik configuration.
# 2024-10-30 00:44:50 by RouterOS 7.16.1
# software id = #
# model = RB941-2nD
# serial number = #
/interface wireless
/interface vlan
/interface bonding
/interface wireless
/ip kid-control
add address-pool=default-dhcp interface=home-vlan10 lease-time=10m name=\
    defconf
add address-pool=guest-dhcp interface=guest-vlan22 lease-time=10m name=\
    guestconf
/queue simple
/routing ospf area
/routing table
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
add bridge=bridge comment=defconf interface=pwr-line1 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged interface=wlan1 \
add bridge=bridge disabled=yes ingress-filtering=no interface=bonding1 \
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
set udp-timeout=10s
/ip settings
/ipv6 settings
set auth=sha1,md5
    public-key="#"
add address=192.168.88.1/24 comment=defconf interface=home-vlan10 network=\
    192.168.88.0
add address=192.168.84.1/28 comment=guestconf interface=guest-vlan22 network=\
    192.168.84.0
    192.168.100.0
    192.168.2.0
add address=172.16.0.2/24 comment="Cloudflare WireGuard" interface=wireguard1 \
    network=172.16.0.0
add address=192.168.68.1/30 comment=debugging interface=ether4 network=\
    192.168.68.0
/ip dhcp-client
    # server=defconf
    # server=defconf
    # server=defconf
/ip dns static
    invalid
/ip firewall mangle
    tcp-mss=1381-65535
/ip ipsec profile
    0.0.0.0/0 gateway=1.1.1.1 routing-table=main scope=10 \
    1.1.1.1/32 gateway=192.168.100.1 routing-table=main scope=10 \
/routing rule
    table=to-Cloudflare
    table=to-Cloudflare
/system clock
/system note
/system scheduler
    start-time=startup
/system script
    #.duckdns.org\"];\
    \n\
    domains=#.duckdns.org&token=\
    urrentIP);\
    \n        } else={\
    entIP);\
    \n        }\
    \n    }\
    \n}"
/tool mac-server
yes I’m using this https://github.com/ViRb3/wgcf to generate cloudflare VPN warp connection for wireguard.
cloudflare also provide 1.1.1.1 1.0.0.1 dns.
:slight_smile:
Changes only
BY the way your bridge ports were not adjusted, if you dont apply recommended changes we cannot progress, and note that taking ether4 off the bridge means NOT having it as bridge port!
Also removed ref to powerline, your router doesnt have an extra powerline connection that I am aware of… how do you connect to powerline products???
You didnt remove bridge from interface list.
You didnt add in extra security!! TRUSTED interface etc…
Forgetting the input chain rules I recommended at least change the forward chain as per below…
Rule of thumb is do not use same dns address as being used for recursive so will use other…
After more thought, its a bit trickier than first imagined.
The complexity is that we want to allow guest to use WAN1 but not WAN2
BUT, we want all traffic to go out wireguard for internet.
Thus the WAN being used is transparent to the user and in a way to the router.
So have to figure out how to block user from wireguard access if the routing is via WAN2…
I suspect will need netwatch to monitor WAN and use that to modify firewall rule.
That will be in next post not this one.
software id =
model = RB941-2nD
serial number =
/interface wireless
/interface vlan
/interface bonding
add name=TRUSTED
/interface wireless
/ip kid-control
defconf
guestconf
/queue simple
add max-limit=1M/1M name=queue-guest target=guest-vlan22 disable=yes { to isolate this from any current issues, apply later }
/routing ospf area
/routing table
add bridge=bridge ingress-filtering=yes frame-types=admit-untagged-and-priority-tagged interface=ether3 pvid=10
set udp-timeout=10s
set discover-interface-list=TRUSTED
/ip settings
/ipv6 settings
add interface=home-vlan10 list**=TRUSTED**
set auth=sha1,md5
public-key=“#”
192.168.88.0
192.168.84.0
192.168.100.0
192.168.2.0
network=172.16.0.0
192.168.68.0
/ip dhcp-client
server=defconf
server=defconf
server=defconf
add address=192.168.84.0/28 comment=guestconf gateway=192.168.84.1 dns-server=1.1.1.1,1.0.0.1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 dns-server=1.1.1.1,1.0.0.1
/ip dns static
invalid
add action=accept chain=forward comment=“internet” in-interface-list=LAN out-interface=wireguard1
add action=accept chain=forward comment=“guest-WAN1-only” in-interface=guest-vlan22 out-interface=wireguard1
add action=drop chain=forward commment=“drop all else”
/ip firewall mangle
tcp-mss=1381-65535
add action=dst-nat chain=dstnat in-interface=home-vlan10 dst-port=53 to-address=172.16.0.1
add action=dst-nat chain=dstnat in-interface=home-vlan22 dst-port=53 to-address=172.16.0.1
{ ensuring dns request goes through the tunnel vice local }
/ip ipsec profile
0.0.0.0/0 gateway=9.9.9.9 routing-table=main scope=10
9.9.9.9/32 gateway=192.168.100.1 routing-table=main scope=10
/routing rule
table=to-Cloudflare
table=to-Cloudflare
/system clock
/system note
/system scheduler
start-time=startup
/system script
admin policy=read,write,policy,test source=":local resolvedIP [:resolve "
#.duckdns.org"];
\n
urrentIP);
\n } else={
entIP);
\n }
\n }
\n}
/tool mac-server
set allowed-interface-list=NONE
set allowed-interface-list=TRUSTED
I connect powerline product using 5v micro usb port.
why should I add guest-WAN1-only, if the guest-vlan22 is part of the interface list LAN? it should use the ‘internet’ filter rules right?
why drop all else?
I tried the code above and got this
failure: ports can be specified if proto is tcp,udp,udp-lite,dccp,sctp
error, so I assume is TCP protocol.
Now I cannot connect to my network, even don’t even get an IP address.
Here is the new configuration.
# 2024-10-30 22:06:28 by RouterOS 7.16.1
# software id = #
# model = RB941-2nD
# serial number = #
/interface wireless
/interface vlan
add comment=homeconf interface=bridge name=home-vlan10 vlan-id=10
/interface bonding
add comment=extraconf name=TRUSTED
/interface wireless
/ip kid-control
    defconf
    guestconf
/queue simple
add disabled=yes max-limit=1M/1M name=queue-guest target=guest-vlan22
/routing ospf area
/routing table
    admit-only-untagged-and-priority-tagged interface=ether3 \
add bridge=bridge comment=defconf disabled=yes interface=pwr-line1 \
set udp-timeout=10s
/ip settings
/ipv6 settings
add comment=guestconf interface=guest-vlan22 list=LAN
add comment=extraconf interface=home-vlan10 list=TRUSTED
add interface=ether4 list=TRUSTED
set auth=sha1,md5
    public-key="#"
    192.168.88.0
    192.168.84.0
    192.168.100.0
    192.168.2.0
    network=172.16.0.0
    192.168.68.0
/ip dhcp-client
    # server=defconf
    # server=defconf
    # server=defconf
add address=192.168.84.0/28 comment=guestconf dns-server=1.1.1.1,1.0.0.1 \
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,1.0.0.1 \
/ip dns static
    invalid
add action=accept chain=forward comment="Cloudflare WireGuard" \
add action=accept chain=forward in-interface=guest-vlan22 out-interface=\
    wireguard1
add action=drop chain=forward comment="drop all else"
/ip firewall mangle
    tcp-mss=1381-65535
add action=dst-nat chain=dstnat dst-port=53 in-interface=home-vlan10 \
    protocol=tcp to-addresses=172.16.0.1
add action=dst-nat chain=dstnat dst-port=53 in-interface=guest-vlan22 \
/ip ipsec profile
    0.0.0.0/0 gateway=9.9.9.9 routing-table=main scope=10 \
    9.9.9.9/32 gateway=192.168.100.1 routing-table=main scope=10 \
/routing rule
add action=lookup comment="Cloudflare WireGuard" disabled=no min-prefix=0 \
    table=main
add action=lookup disabled=no dst-address=192.168.88.0/24 min-prefix=0 \
    src-address=192.168.88.0/24 table=main
    table=to-Cloudflare
    table=to-Cloudflare
/system clock
/system note
/system scheduler
    start-time=startup
/system script
    #.duckdns.org\"];\
    \n\
    urrentIP);\
    \n        } else={\
    entIP);\
    \n        }\
    \n    }\
    \n}"
/tool mac-server
The good news is that you still can access the router ( hopefully via ether4 ) as you can provide a config. :slight_smile:
Yes Sorry it should be four rules.
add action=dst-nat chain=dstnat in-interface=home-vlan10 dst-port=53 protocol=udp to-address=172.16.0.1
add action=dst-nat chain=dstnat in-interface=home-vlan22 dst-port=53 protocol=udp to-address=172.16.0.1
add action=dst-nat chain=dstnat in-interface=home-vlan10 dst-port=53 protocol=tcp to-address=172.16.0.1
add action=dst-nat chain=dstnat in-interface=home-vlan22 dst-port=53 protocol=tcp to-address=172.16.0.1
How does the usb micro port show up as a selectable option on the r outer???
If it does then yes by all means add it back to /interface bridge ports and bridge vlans
If you noticed, we did NOT add guest vlan to the LAN interface list for a couple of reasons..
a. This specifically prevents the vlan from accessing the local routers WAN because its not permitted to access the router DNS services and thus would never go out of WAn1 or Wan2 ( the only way out would be via VPN WAN )
b. No usual LAN interface to WAN interface list rule, so that no users can go out local WAN
(instead its LAN to WIREGUARD only)
c. we create an extra rule just for guest-vlan because we will disable this single rule using netwatch when WAN1 goes down…
  1. Why are all your bridge ports disabled??? only ether4 should be disabled ( for now ) in any case cleaned up all…
    Why is ether2 on the bridge at all, its one of the WAN ports right?
    Ether3 is a trunk port going to the TPLINK switch, it has no PVID.
Lets fix it…
add bridge=bridge ingress-filtering=yes frame-types=admit-only-tagged-vlan interface=ether3
add bridge=bridge ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=wlan1 pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=wlan2 pvid=22
add bridge=bridge ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=pwr-line1 pvid=10
  1. Adjust for pwr-line
    add bridge=bridge tagged=bridge,ether3 untagged=wlan1,pwr-line1 vlan-ids=10
  2. remove guest vlan from LAN interface list…
  3. You didnt get rid of the default rule which we replaced with other rules…
So should simply look like this:
add action=accept chain=forward comment=“Cloudflare WireGuard”
wireguard1
add action=drop chain=forward comment=“drop all else”
  1. Dont need ping check on second rule of recursive.
    add check-gateway=ping comment=Recursive dst-address=0.0.0.0/0 gateway=9.9.9.9 routing-table=main scope=10 target-scope=12
    add dst-address=9.9.9.9/32 gateway=192.168.100.1 routing-table=main scope=10 target-scope=11
    add check-gateway=ping comment=Backup distance=2 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-table=main
    add comment=“Cloudflare WireGuard” dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=to-Cloudflare
  2. Routing rules seem to have been changed, reworked to this…
    /routing rule
    add action=lookup-only-in-table comment=“maintain local connectivity” min-prefix=0 table=main
    add action=lookup-only-in-table src-address=192.168.88.0/24 table=to-Cloudflare
    add action=lookup-only-in-table src-address=192.168.84.0/28 table=to-Cloudflare
  3. Only winbox variant is encrypted, so
    /tool mac-server
I don’t know, it just shows on default/factory configuration :slight_smile: , but the micro usb port only for power, not data, I think so :slight_smile: .
Why should add these ? how about if website request another ports that not provided ?
  1. You didnt get rid of the default rule which we replaced with other rules…
wireguard1
I need to disable this
right ?
Now I can get IP address from the router, but no internet connection.
# 2024-10-31 06:44:06 by RouterOS 7.16.1
# software id = #
# model = RB941-2nD
# serial number = #
/interface wireless
/interface vlan
/interface bonding
/interface wireless
/ip kid-control
    defconf
    guestconf
/queue simple
/routing ospf area
/routing table
    admit-only-untagged-and-priority-tagged interface=pwr-line1 \
set udp-timeout=10s
/ip settings
/ipv6 settings
set auth=sha1,md5
    public-key="#"
    192.168.88.0
    192.168.84.0
    192.168.100.0
    192.168.2.0
    network=172.16.0.0
    192.168.68.0
/ip dhcp-client
    # server=defconf
    # server=defconf
    # server=defconf
/ip dns static
    invalid
    connection-state=new disabled=yes in-interface-list=WAN
    wireguard1
/ip firewall mangle
    tcp-mss=1381-65535
    protocol=udp to-addresses=172.16.0.1
/ip ipsec profile
/routing rule
add action=lookup-only-in-table comment="maintain local connectivity" \
    disabled=no min-prefix=0 table=main
    table=to-Cloudflare
/system clock
/system note
/system scheduler
    start-time=startup
/system script
    #.duckdns.org\"];\
    \n\
    urrentIP);\
    \n        } else={\
    entIP);\
    \n        }\
    \n    }\
    \n}"
/tool mac-server
