Hello everybody, okay?
I have a dedicated link with 6 ips valid.
I need to pass one of these IPs to a computer with private ip.
Can anyone help me?
Can anyone help me?
hi…
plz decribe the details!
pass from ether?
or pass from connection ?
or…
Let me try:
My Cisco router: 200.xxx.xxx.137/29
The eth1 of my RB450G: 200.xxx.xxx.138/29
The eth2 of my RB450G: 172.16.20.1/24
NAT: chain=srcnat action=masquerade out-interface=eth1
Now I want a computer, connected via eth2, works with ip 200.xxx.xxx.139. Well said, I want to pass the public ip to it.
Or I put the public ip straight to your computer or that I put my ip in eth1 RouterBOARD and make a pass on the public ip to private ip, whatever.
What are the chances?
I hope I was clear. Thanks.
Add the IP to WAN interface and use NAT to translate it 1:1.
correct, then I do it this way:
/ip firewall nat add chain=dstnat dst-address=172.16.20.x
action=netmap to-addresses=200.xxx.xxx.139
/ip firewall nat add chain=srcnat src-address=200.xxx.xxx.139
action=netmap to-addresses=172.16.20.x
1º am I right?
2º these rules must be before the masquerade?
3 º i doing this, no need to tamper with anything, right?
4º if I want to put the public ip straight into the computer’s network card, what is the most practical means, that I still can do bandwidth control that computer?
Thanks.
solved;
thanks fewi.
