How to port forward on VLAN public IP
Hi All,
I have a MikroTik RB760iGS with single port connected to WAN.
The RouterBoard works great for my multiple server system running behind the NAT.
Recently I bought another IP(v4) from my ISP which I assigned through ip>addresses and NATd some of the ports to a single server and it works great too.
However, later I also purchased three more IP(v4) for my other servers, which when I add through ip>addresses does not see any traffic coming to the server.
The server is setup correctly to serve a webpage and I can connect to the website via local network without any issues.
I have also set up the NAT for the web traffic for that IP and server.
Now, to troubleshoot, I am wanting to know the following:
  1. Assuming the Mikrotik configuration is in fault and no traffic is passing though the router, can I still use the Torch tool to check if the ISP has setup the ip’s correctly (they told me it is served via a framed IP) by monitoring traffic arriving on that particular IP.
  2. Is there any other settings I need to change for multiple WAN ips in a single port via framed routing (my original DHCP ip and second IP are working fine with just adding the IP address in ip>addresses) but none of the new IPs see any traffic.
Some more information from the ISP.
It appears the additional IPs are setup through VLAN on a single port.
So, I have added ISP IP address to interface VLAN20.
How do I setup port forwarding from the VLAN ISP IP to local server 10.0.0.170 and vice-versa?
Thanks,
