How to portforward SSH between 2x Mikrotik
Hi!
Got some problem - I can’t establish SSH connection between two different locations (Physical, ISP and white IP’s are different).
The scheme is:
WinPCfirewallMikrotik/GuestWANMikrotik/HostLinux/Firewallserver.
Firewall: made a rule accept/upcoming-outgoing/TCP/SSH_PORT/distant-IP-address
Mikrotik/Guest: made a Firewall rules
for Filter rules
and NAT:
Mikrotik/Host: made a Firewall rules
for Filter rules
and NAT:
Linux/Firewall: add a rule
ufw allow from GUEST_IP to any port SSH_PORT
Looks like I have missed something or get mistakes somewhere,
because I’m still getting … Connection timed out
SSH works fine in these LOCAL nets but WAN between them can’t establish.
What I’ve made wrong?
Please help.
The problem solved by myself.
The solution is:
HOST:
GUEST: settings is the same.
Place the rule higher in Filter Rules list.
Hope it could save some time to somebody.
