I see that the CCR1009-8G-1S-PC can be powered via poe. We normally use cisco sg300 poe switches, and connect the modem to port 1 on the Mikrotik, and the cisco to port 2 on the Mikrotik. If we instead connect the cisco to port 8 of the Mikrotik, which is the poe port, will that power the device?
according to the quick guide available from routerbaord.com, it accepts only passive PoE. To me that means you can only use the gigabit PoE injector that is available from your distributor.
