How to print tx/rx Bytes using CLI and API?
how can I print this information from the command line
tx/rx Bytes
and is it possible to get to this information using API?
I would like to check and store the values ​​in the database.
Of course, if for this you can use the command-traffic monitor your EoIP or any interface.
interface monitor-traffic eoip-tunnel_1_5 interval=2s (1s, 3s etc)
As for the API Similarly, all depends what values ​​you want to store and every time, you could retrieve all values ​​and before storing your DB values ​​need to cut and store, with a statement of its programming language, or directly in the database with some stored procedure.
Apologies for my writing I am using a translator. :frowning:
Regards.
I have the very same question as mysz0n.
Unfortunately, the command
/interface monitor-traffic <interface>
just shows realtime data, whereas Winbox is able to show the total rx/tx bytes (since last reboot, or so).
How to get this info on CLI?
EDIT:
I found the command:
/interface print stats
