Some files Router was crash because of some problem . Now I want to re install my Router OS but I don’t have key . Is there any other way to install it with the existing key?
If anyother solution is there please let me know.
Use netinstall, than previously installed key will be kept on the router.
Thanks for your Reply,
I know I have 3 options to reinstall it.
But How can I get that my Existing Key?
Waiting 4 your reply…
You do not need existing key. If router was licensed, Netinstall will use the previous key (it will be shown ‘keep previous key’ in ‘Key’ menu ).
