how to read a value from txt-file and change it ?
Hello all ,
I want to do a simple thing -
I have a txt file with 1 line :
“the number is - 1”
now I want that every time I run script the sentence in the txt-file will change +1
"the number is - 2 "
I don’t know how to read only the value.
any help ?
Thanks ,
I have manage to read the file , but it won’t give me to add +1.
this is what I did:
:global num [/file get test.txt contents]
:environment print
"num"="4
:set num ($num +1);
Script Error: cannot add string to time interval
can anyone help?
Thanks ,
