how to reboot for more than 1 minute
can anybody help me,
this is my scenario, if mikrotik received sms for less than 1 minute then proceed
if more than 1 minute the usb port reboot and remove the usb port
:foreach i in=[/tool sms inbox find where message=“2”] do={
:if ([/tool sms inbox get timestamp] < 1m) do={
/system script run [find name=“*2”]
:if ([/tool sms inbox get timestamp] > 1m) do={
/sys routerboard usb power-reset
/tool sms inbox remove $i;
:delay 4s;
/port remove usb
:delay 10s
/tool sms set port=usb
} on-error={:log error message="
Create a Scheduler with parameter “start-time=startup”
And use “:delay 60” to wait 60 sec before executing your script.
Exemple :
thats not possible. its only a delay.
Maybe i didn’t understand your Request…
I taught you needed a way to Check 60 Sec after boot,
If your device received a SMS and if not Reset USB
What did i understand wrong ?
sorry for my bad english
if mikrotik received sms in less than 1 minute
then call script name *2
if more than 1 minute since mikrotik recieved the message
execute of rebooting usb port
i need to reboot the usb port because sometimes sms in mikrotik hang and cannot delete
Ahhh …It was my mistake
When receiving a SMS the modem sometimes get “Stuck”
Because of this, you want to constantly check if the modem is “Stuck”
and if so, reset the Modem / USB-Device.
yes sir like for example
mikrotik received sms at 12:00pm.
and if sms stuck and cannot delete at 12:02pm
thats 2 minutes already then reset the Modem / USB-Device by executing in /sys routerboard usb power-reset
anyone can help pls
