how to recover hotspot folder and files on Mikrotik hap AC lite
Hi
I have by mistakenly deleted the hostpot folder from files directory. can you pleas help to get those folder and respective files back.
setup the hotspot again. i once had the same, if you create a new hotspot file are generated again.
try to enable / disable hotspot first, maybe that also helps
Thanks ..i have downloaded the hotspot folder from forum and copied the same.
But now i am facing another problem.
i want to configure one public ip to device, i have configured that on quickset on internet configuration but still it not worked..need help to assign the public ip to server
