how to redirect to and from squid server ????
hi everyone
i am just trying to implement squid server in my lab.
this is for my small setup for testing.
i have configured the squid well and my network setup is
ehter1 -internet------mt450g
| |ether5(for lan connectivity
( squid)| |
switch
here main link comes to mt routervoard ehter1 and ether5 is for my lan
and squid is connected to mt router ether4 (here squiid has single lan card ).
[admin@MikroTik] > /ip address print detail
0 ;;; wan
address=10.210.2.5/24 network=10.210.2.0 broadcast=10.210.2.255
interface=ether1 actual-interface=ether1
1 ;;; lan
address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255
interface=ether5 actual-interface=ether5
2 ;;; proxy
address=192.168.1.1/24 network=192.168.1.0 broadcast=192.168.1.255
interface=ether4 actual-interface=ether4
[admin@MikroTik] > /ip route print detail
0 S dst-address=0.0.0.0/0 gateway=192.168.1.2
gateway-status=192.168.1.2 unreachable distance=1 scope=30
target-scope=10 routing-mark=http
1 A S dst-address=0.0.0.0/0 gateway=10.210.2.1
gateway-status=10.210.2.1 reachable ether1 distance=1 scope=30
target-scope=10
2 ADC dst-address=10.210.2.0/24 pref-src=10.210.2.5 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
3 ADC dst-address=192.168.0.0/24 pref-src=192.168.0.1 gateway=ether5
gateway-status=ether5 reachable distance=0 scope=10
4 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=ether4
gateway-status=ether4 unreachable distance=0 scope=200
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
add action=mark-routing chain=prerouting comment=“” disabled=no dst-port=80
new-routing-mark=http passthrough=no protocol=tcp src-address-list=squid
add action=masquerade chain=srcnat comment=“for lan masq” disabled=no
out-interface=ether1
add action=masquerade chain=srcnat comment=“” disabled=no dst-port=80
protocol=tcp
add action=dst-nat chain=dstnat comment=“nst nat” disabled=no dst-port=80
protocol=tcp to-addresses=192.168.1.2 to-ports=8080
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
here is my mt routerboard 450g setup. if there is any mistake kindly tell me
note :- all lan client are running in static ip via dhcp server that is configure in mikrotik 450g (simple natting for lan client to browse internet).
with regard
suraj kumar.
india
Is this squid in fully transparent mode you - then you need to consider L2 redirect or policy routing.
Otherwise you could simply look at http://aacable.wordpress.com/2011/12/30/howto-add-squid-proxy-server-with-mikrotik-short-reference-guide/ as a good start.
thanks for your reply :slight_smile:
yes this is fully transparent.one thing i want to ask,can i use single lan card on squid server.
main link will be on mt 450 ether1 and ether2 will be used for lan and ether 3 would be for squid server .
