How to redirect traffic from googledns to other dns provider
Please help me to implement following iptables instruction which redirect LAN traffic from google dns to other dns provider (69.42.56.54).
iptables -I PREROUTING -t nat -p udp -d 8.8.4.4 --dport 53 -j DNAT --to-destination 69.42.56.54
iptables -I PREROUTING -t nat -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination 69.42.56.54
Additionally this should work not for whole LAN just only for 3 internal (LAN) IP 192.168.10.40, 192.168.10.43, 192.168.10.50.
Use destination NAT rules in IP Firewall.
correct?
/ip firewall nat add chain=dstnat protocol=udp src-address=192.168.10.40 dst-address=8.8.8.8 src-port=53 action=dst-nat to-addresses=69.42.56.54 to-port=53
to make same as:
iptables -I PREROUTING -t nat -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination 69.42.56.54 only for LAN IP-192.168.10.40 ?
You have the src port in the rule - should be dst port. The client could use a variety of ports as the src port.
/ip firewall nat add chain=dstnat protocol=udp src-address=192.168.10.40 dst-address=8.8.8.8 dst-port=53 action=dst-nat
By using dst-address-list and src-address-list, you can accomplish your aim with only one rule.
add chain=dstnat protocol=udp dst-address-list=google_dns dst-port=53 action=dst-nat
to-addresses=69.42.56.54 to-port=53 src-address-list=no_google_dns
/ip firewall address-list
add address=8.8.4.4 list=google_dns
add address=8.8.8.8 list=google_dns
add address=192.168.10.40 list=no_google_dns
add address=192.168.10.43 list=no_google_dns
add address=192.168.10.50 list=no_google_dns
Thanks !!!
