I have a RB2011UiAS-2HnD-IN which has been running OpenWrt for a while. I now want to go back to RouterOS (to pass it on to someone else).
Can anyone tell me how to set about doing this? I probably need to download RouterOS as I don’t think I saved the version that was originally installed. Also do I need any sort of software key?
I have a serial connection available to the RB2011, that was how I was loading OpenWrt. Presumably I can use this to load RouterOS.
I did look at the OpenWrt guide for the Mikrotiks but it says little or nothing about re-installing except to remember to keep the key. Netinstall is WIndows and I don’t have any Windows machines, not any experience of using them.
I’m afraid Netinstall might be the only mean to (re)install RouterOS on a device that does not have a functional RouterOS installed already. If I remember correctly, Netinstall has been reported to work fine under Wine, so that may be an option for you.
Windows + Netinstall. You could virtualize Windows using for example VirtualBox (and bridge network connection). Ask Google how to get Win10 iso, you can do it legally.
