how to remove a active connections with API PHP?
hi, i need remove active connections from PPPOE of a single user from with PHP API
paste a capture screen.
routeros_api.class.php use. my syntax is similar to the following but no found
by terminal I run this command: interface pppoe-server remove
<?php include('routeros_api.class.php'); $Username="laklfasd"; $Pass="sadasjkdaskljd"; $api_puerto=8728; $usuario = 'asdjlkasdl'; $ipRouteros = 'asdñaksdl'; //$comando = 'interface pppoe-server remove '; \ \ \ \ $API = new routeros_api(); $API->debug = true; if ($API->connect($ipRouteros , $Username , $Pass, $api_puerto)) { $API->comm("interface pppoe-server remove "); } ?>
THANKS!!!
try something like
$API->write(‘/interface/pppoe-server/print’, false);
$API->write(‘=.proplist=.id,name’);
$ARRAY = $API->read();
foreach($ARRAY as $keys=>$val){
if($ARRAY[$keys][‘name’] == ‘’){
$API->write(‘/interface/pppoe-server/remove’,false);
$API->write(‘=.id=’.$ARRAY[$keys][‘.id’]);
or
$API->write(‘=.proplist=.id’, false);
$API->write(‘?name=’);
$API->write(‘=.id=’.$ARRAY[0][‘.id’]);
I would print the output of $ARRAY via print_r($ARRAY) to make sure that is right on the id.
That is one way . you may need to fiddle with the exact pppoe fields but think that will work.
not found :frowning: :frowning:
returns
‘Connection attempt #1 to 10.28.1.2:8728… <<< [6] /login >>> [5/5] bytes read. >>> [5, 39]!done >>> [37/37] bytes read. >>> [37, 1]=ret=2cf454b8e830f77b78d7a9d5b33a73 <<< [6] /login <<< [14] =name=prueba <<< [44] =response=00473cbb0bc842e37c2aae464e44b07d >>> [5/5] bytes read. >>> [5, 1]!done Connected… <<< [42] /interface/pppoe-server/remove=.id=*F2CEFC’
but no delete to PPPO-SERVER
the user is 14703 do not know if you can delete via user.
