How to remove a dynamic DNS?
Hi Friends
I use a Mikrotik hap ac2. I want to remove dynamic DNS server. I read this forum and found a solution from Mikrotik Support:
Disable dhcp-clients “user-peer-dns” function:
/ip dhcp-client set 0 use-peer-dns=no
/interface lte apn set use-peer-dns=no
and then digit: 0
I did it but the dynamic DNS server was not removed.
Could you suggest the right way?
removed from where? pc, smartphone or on DNS page of RouterBOARD configuration?
I want to remove address of the DNS server of the Internet provider from the DNS page of RouterBOARD configuration.
If you connect with your ISP wiht pppoe or with a DCHP-client uncheck the Box ‘use Peer DNS’ (Winbox) or set
use-peer-dns=no
(terminal).
Just remove check mark from “Use Peer DNS” in DHCP client config on RouterOS like here:
Try to paste on terminal this…
/ip dhcp-client set [find] use-peer-dns=no
/interface lte apn set [find] use-peer-dns=no
/interface ppp-client set [find] use-peer-dns=no
/interface pppoe-client set [find] use-peer-dns=no
I did it but it doesnt help to remove dynamic DNS
Have you restarted the connection also?
Yes of cause
Any sort of VPN active?
Maybe ensure no entries in dynamic servers and remote is NOT checked off?
At this point, put the result of
/export hide-sensitive
on forum.
Remove sensitive data, like serial number, real ip, email, username and passwords (ignore MAC addresses, are not sensitive until the “hacker” is not inside your house…)
Do not remove what you think is unuseful, just censore.
MikroTik RouterOS 6.49.6 (c) 1999-2022 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@MikroTik] > /export hide-sensitive
may/14/2022 09:46:16 by RouterOS 6.49.6
software id = 71ZR-70ZS
model = RBD52G-5HacD2HnD
serial number = XXXXXXXXXXXXXX
add admin-mac=74:4D:28:BF:66:CB auto-mac=no comment=defconf name=bridge
/interface l2tp-client
add connect-to=public-vpn-134.opengw.net disabled=no name=VPN use-ipsec=yes use-peer-dns=exclusively user=vpn
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-b/g/n channel-width=20/40mhz-XX country=russia3 disabled=no distance=indoors frequency=auto
hw-protection-mode=rts-cts installation=indoor mode=ap-bridge ssid="Lugovaya 1-1-48" wireless-protocol=802.11
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country="united states3" disabled=no disconnect-timeout=5s distance=
indoors frequency=auto hw-protection-mode=rts-cts installation=indoor mode=ap-bridge scan-list=5100-5300 ssid="Lugovaya 1-1-48" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.2.4-192.168.2.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/interface pptp-client
add allow=mschap1,mschap2 connect-to=XX.XX.XX.XX disabled=no keepalive-timeout=disabled name=pptp-out1 profile=default user=user2
/routing bgp instance
set default as=64512 ignore-as-path-len=yes router-id=XX.XX.XX.XX
add bridge=bridge comment=defconf interface=wlan2
/ip accounting
set enabled=yes threshold=1600
add address=192.168.2.1/24 comment=defconf interface=bridge network=192.168.2.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall address-list
add address=2ip.ru list=VPN
add address=rutracker.org list=VPN
add address=svoboda.org list=VPN
add address=meduza.io list=VPN
add action=accept chain=input comment="Remote access to Mikrotik Igor" dst-port=8291 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=VPN new-routing-mark=To_VPN passthrough=yes
add action=masquerade chain=srcnat comment="Igor VPN" out-interface=VPN
add distance=1 gateway=VPN routing-mark=To_VPN
add distance=1 dst-address=192.168.0.0/24 gateway=172.16.30.1
add distance=1 dst-address=192.168.1.0/24 gateway=172.16.30.1
add distance=1 dst-address=192.168.3.0/24 gateway=172.16.30.1
/ip service
set www address=192.168.2.0/24
/ip smb
set domain=XXXXXXXXX enabled=yes
/ip smb shares
add directory=/disk1 name=disk1
/ip smb users
add name=admin read-only=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/routing filter
add action=accept chain=bgp_in comment="Set nexthop to VPN" set-in-nexthop-direct=VPN
/system clock
set time-zone-name=Europe/Moscow
/tool graphing interface
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
set VPN use-peer-dns=no
So this was right: http://forum.mikrotik.com/t/how-to-remove-a-dynamic-dns/157978/1
This works fine.
Thank you all very much.
To me the router is a security nightmare.
(1) add action=accept chain=input comment=“Remote access to Mikrotik Igor” dst-port=8291 protocol=tcp
(2) /ip service
See my reply here:
http://forum.mikrotik.com/t/remote-access/150805/2
As a first rule, you do open internet to access port 8291…
/ip upnp
set enabled=yes
Should I turn on UPnP on router?
A Trojan horse or virus on a computer inside your network could use UPnP to open a hole in your router’s firewall to let outsiders in. So it’s a good idea to turn off UPnP when not in use. …
I do use UPnP, but I do monitor it, so I have ok control of every host that uses it,why and when. (using Splunk)
