How to remove a sim card from SXT LTE?
Hello folks,
One of my collegues inserted a sim card in our recently bought SXT LTE. We are trying to remove the sim card to test it in a cell phone and oddly we couldn’t find a safe way to remove it without damaging the device. We are not able to see any approach to slide the sim card back from the slot once it was inserted safely with tools or bare hands. The manual has no instruction regarding this procedure.
Are we missing something? Suggestions? Thanks in advance
Isn’t it spring loaded? Press to release?
No, it is not. This is the main reason we are baffled.
Small push on opposite side + tweezers magic :wink:?
The other side isn’t reachable at all, unless we bend a hard metal piece specifically tailored for this. Tweezers are also a bad option because the chip lays way to close to the greenish “motherboard”, close to circuit trails and buttons.
