How to remove a static route using API?
Example:
ip route print where dst-address =192.168.153.2/32
 1   S  192.168.153.2/32                     wlan2              1
API:
/ip/route/print
?dst-address=192.168.153.2/32
stReturnSentence.szSentence[0] = !re
stReturnSentence.szSentence[1] = =dst-address=192.168.153.2/32
stReturnSentence.szSentence[2] = =gateway=wlan2
stReturnSentence.szSentence[3] = =gateway-status=wlan2 unreachable
stReturnSentence.szSentence[4] = =distance=1
stReturnSentence.szSentence[5] = =active=false
stReturnSentence.szSentence[6] = =static=true
stReturnSentence.szSentence[0] = !done
Sentence iLength = 7
Sentence iReturnValue = 0
“id” not present, “find” not work.
what version do you use? for me v4.2 and v4.6 works fine
I use 5.0beta2. Please show an example of removing the route using an API.
I mean, in v4 ‘.id’ field is present. AFAIR, somebody have already complained about missing API parameters in v5.0beta - try v4
In v4.9 field is not present :frowning:
