Hi
I am using evilfreelancer/routeros-api-php . I am trying to make a query so that pppoe active user from a mikrotik can get disconnect. I tried many methods with the php query but in debug it shows “NO Such Command”. Normally if i type in mikrotik terminal interface pppoe-server remove it removes the user. Also i tried ppp active remove numbers= . Both resulted same response '‘no such command’
This is the sample query
public function disconnectConnectedUser()
$query_ppp_deactive_user = new Query(“/interface/pppoe-server/print”, [‘name’, ‘pppoe-user01’]);
$user = $this->client->query($query_ppp_deactive_user)->read();
$data = $user[0][‘.id’];
$deactive_user = new Query(“/interface/pppoe-server/remove/numbers=$data”);
return $this->client->query($deactive_user)->read();
I can get full pppoe active list via API! used many ways including username sessionid. all resulted same response from api"no such command"
What am i doing wrong?
