To delete an address list called my_addresses, do from the command line:
/ip firewall address-list remove [/ip firewall address-list find list=my_addresses
Can anyone confirm this is broken in RC13 and if so is there a workaround for the moment?
Regards,
Malcolm
/ip firewall address-list remove [/ip firewall address-list find list="my_addresses"] ;
Is it possible for a firewall rule to trigger removing an IP from an address list?
/Chris
No, you can’t. But if you add to address list by firewall rule, then you can specify timeout how long that entry will stay there.
Perhaps a feature request is in order? I was hoping that adding the IP address a second time with a timeout of 1ms would fix the problem.
Maybe you can give some real-life example when such feature is needed?
