Hi guys,
I am using RB411 with sierra wireless MC7710
It is working well with almost no problems, but I have problem with GSM mode.
LTE interface network-modes are GSM, 3G, LTE and ofc “auto”. I need to remove gsm, because it is causing me problems with low traffic.
Is there any chance to remove GSM mode from LTE? (by script or command or etc.? )
You can set the mode through AT commands, so it could probably be scripted, although it would definitely take some fine tuning to get it right. That is one of the password protected commands, so it shouldn’t be posted here. If you are not familiar with the commands, you can download the extended AT commands from Sierra Wireless. You will need to get the password from your distributor. What about improving the signal quality enough that it doesn’t try to use GSM? Would that be an option?
