I have 4 ppp-client
for 2 of them I put comment .
I want to remove the other 2 with a script
if I do this
/interface ppp-client remove [find where comment!=0]
it remove me the 2 with comment ,
have try
/interface ppp-client remove [find where comment=0]
but it doesn’t do nothing
so what to do ?
Thanks,
use “”!
Do
/interface ppp-client remove [find where comment=“remove this”];
or
/interface ppp-client remove [find where comment!=“do not remove this”];
O.K.
now I have 2 ppp-client I don’t want to remove
how can I keep both of them ? how do I use "and & " for it?
can I do this?
/interface ppp-client remove [find where comment!="test1"]&&[find where comment!="test2"];
David1234:
O.K.
can I do this?
Use my example…
You know that you can put same comment on more than one ppp?
I understand your script, but eventually must be writed:
/interface ppp-client remove [find where comment!=“do not remove this 1” and comment!=“do not remove this 2”];
2 things :
I don’t want to use the same comments for both of them. this is why I use comments
if the other 2 don’t have comments - it doesn’t remove them.
so I thought maybe something like this remove only the ones with no comments)
/interface ppp-client remove [find where comment=""];
but is also doesn’t work.
Thanks ,
/interface ppp-client remove [find where (comment . “”)=“”];
Thanks!!
Can you please explain to me the structure of the command?
empty_comment = nil (nothing)
nil = “” → false (as boolean results)
nil + “” = “” (as addiction)
empty_comment + “” = “” (as addiction)
“” = “” → true (as boolean results)
